Saltar al contenido principal
Lanzado en Septiembre 16, 2016. Modelos 1660, 1778. Disponible en GSM o CDMA / 32, 128, o 256 GB / Oro Rosa, Oro, Plata, Negro Mate y Negro Brillante.
Preguntas 2264 Ver todo
Why is my iPhone stuck in 1% and restarting itself every few minutes?
So i wake up this morning and i dropped my iphone 7 from the bed, i went back to sleep and when i wake up my phone was on 1%,I tried charging it but it shows 3% or 5% and it restart itself every few minutes and the apple logo appears 2 times and it shows again 1%,the battery health shows "the iphone is unable to determine battery health", it was 84% before this happened.I tried to charge it after that and it go to 100% directly before to restart and when it restart it's again 1%.
i changed my screen 2 months ago.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
2 Respuestas
Respuesta Más Útil
Hmm if you changed your screen, did you replace the plate over the battery? Open it up and disconnect and reconnect it. Maybe it just jostled apart during the fall. Try that, and let me know how it goes :)
Fue útil esta respuesta?
Puntuación 1
4 comentarios:
it wasn't me who changed i took my phone to a repair shop. but i think that may be the problem.
- de
Then yes, I would take it to the shop where you got the screen changed. Let them know the problem, and the suggested solution. I have ran across this problem many times at my shop.
- de
thank you i will, i hope i don't have to change the battery .
- de
No problem. Hopefully you don’t (:
- de
Such problem accedentily happen by the following region.Actually that is related to SWI Line problem.
1- Battery must have problem.
2-Battery connector
3- Loose contact of battery to battery connector SWI line.
Battery have 3 pins,one is +ve,-ve & SWI.
On that cases if the problem still same after doing this you have to follow this process but remember need micro-soldering skills.
Puntuación 1
Añadir tu respuesta
lor mo estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 8
Ultimos 30 días: 43
Todo El Tiempo: 1,469
