Saltar al contenido principal
Guias de reparación y de desenemblaje para la Compaq Presario CQ40.
Preguntas 36 Ver todo
Can I use ethyl alcohol?
can I use ethyl alcohol 70% to clean my device ?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 2
5 comentarios
ethyl alcohol is for drinking. A 70% would be 140 proof. Just what do you have?
- de
I bought it from the pharmacy It's used for medical purposes And product name is (PURE Nautre's Purity)
- de
If its pure, then you should use it. My answer is YES!
- de
I would strongly recommend using isopropyl rubbing alcohol as, it does not leave as much of a residue as ethyl alcohol can. Electronics are very sensitive.
- de
Thank you for helping me. I will use ethyl alcohol in this period then Later I will try to get isopropyl alcohol to avoid any damage
- de
Agregar un comentario
2 Respuestas
Respuesta Más Útil
You can, but the high vapor pressure means it will evaporate much quicker than an alcohol more suited to cleaning like isopropyl. Make sure it doesn’t contain any other chemicals that could be left on the device when the alcohol evaporates.
Fue útil esta respuesta?
Puntuación 1
1 comentario:
thanks for answering
- de
Please look at this question: What are Professionals Using for Screen Cleaning
Puntuación 1
Añadir tu respuesta
Amr Ateef estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 9
Todo El Tiempo: 412
