Saltar al contenido principal
Lanzado el 25 de septiembre de 2015. Modelo A1688 / A1633 . La reparación de este dispositivo es similar a las generaciones anteriores, que requieren destornilladores y herramientas de palanca. Disponible como GSM o CDMA / 16 , 64 , o 128 GB / plata, oro, gris espacio, o la opcion de oro rosa.
Preguntas 2688 Ver todo
Can’t hear on incoming calls
Volume to low when all the way up. Can’t hardly hear the other person on the other line
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
1 comentario
I have the same problem and have to use a Bluetooth speaker. The problem is that it causes an echo for the other caller
- de
Agregar un comentario
1 Respuesta
Respuesta Más Útil
It is probably the earpiece speaker that is going bad. Make sure the front facing camera and the proximity sensor are working. If they are both in working condition, I would replace the earpiece speaker first. If the camera or proximity sensor is not working, it is most likely the cable that contacts the earpiece speaker. Both of these parts are inexpensive and the repair is pretty straight forward. This is the link for the ifixit tear down of it, Remplazo de Auricular de Pantalla de iPhone 6s
Fue útil esta respuesta?
Puntuación 1
1 comentario:
First thing I always do is just run a brush on the speaker grill at the top of the screen.
It might take a bit of time but it saves opening up the phone to clean out the grills. The key is to have finer bristles (smaller is better for cleaning).
- de
Añadir tu respuesta
Mark Levret estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 160
