What is the proper wiring for HyperX Core Stinger TRRS connector?
I am rewiring a broken TRRS connector.
Unfortunately, the plug was so damaged that I am unable to probe the TRRS plug with the wires to determine the positions.
Since most HyperX devices are CTIA - the wiring should be:
Tip - Left Audio
Ring 1 - Right Audio
Ring 2 - Ground
Sleeve - Microphone
My issue is that it seems I have 6 wires.
RED / GREEN / Striped BLUE-COPPER / BLUE / WHITE with surround copper
The colors don’t seem to matter. Doing research on this yielded different color combination wiring from different headsets.
So I was looking for advice / confirmation on my wiring.
So for I have the audio working but not the mic.
(as an extraneous question, should the mic work if connected to a smartphone?
I wired it
TIP - GREEN (Left Audio)
Ring1 - RED ( Right Audio)
Ring 2 - Striped Blue-Copper (Ground)
Sleeve - White (Mic)
My direct question is:
Is the copper souring the white wire the Mic ground and attached to Ring 2?
Where does the blue wire go? Is that also a ground for the audio or mic?
I would really appreciate some help. Thank you.
Es esta una buena pregunta?
