Saltar al contenido principal
Lanzado el 22 de septiembre de 2017. Modelo A1864, A1897. Disponible como GSM o CDMA / 64 o 256 GB / oro, plata y gris espacio.
Preguntas 677 Ver todo
Why is my wifi grayed out?
Hey, I have an iphone 8 plus that has wifi grayed out, but will still connect to cellular. Any ideas? I have already reset it entirely and it still didn’t work.
Es esta una buena pregunta?
Puntuación 2
Agregar un comentario
4 Respuestas
Solución Elegida
Broken wifi chip which requires board level repair, that’s it.
Wifi and cellular are unrelated.
Fue útil esta respuesta?
Puntuación 2
6 comentarios:
Why can't it be the wifi antenna?
- de
It’s definitely not the antenna, the logic function is not working, so it’s a chip issue.
It’s like when your car won’t start, but you are suspecting there is something wrong with the tire.
- de
If the antenna is “broken” (common with iPhone 6), you get very low signal. When the WiFi function altogether is missing, then the wifi circuit is down. A lot of times from drop damage (common with iPhone 7), sometimes from electrical damage (common with iPhone 6s).
- de
I had same issue, ended up being a software issue, I noticed also at the same time I had a greyed out wifi, my phone. Would randomly not charge, this to was fixed with my new software
- de
Hi, im 16. How do i know what the problem is? Wether if its the antenna or the board? The Wi-Fi is greyed out, I don't have cellular data, and I'm trying to repair myself. What should I do?
- de
Mostrar 1 comentario más
That sounds like WI-FI chip is damaged or dry soldered.There have two factor that you can solve by this way.
Sometime WI-FI chip dry soldered throw over heat that remove PCB from board and re-hot WI-FI chip on 240 aprox 1 min then check most of the cases are solved.If the problem is still same remove the WI-FI chip then re-ball and fix.
If you have to change the WI-FI chip that need to unbind the Nand chip too.So,you need the Nand programmer to unbind WI-FI address or WI-FI address unlocked.If you have to know further this may help you.Have all process 7,7Plus and 8,8Plus have same process.
Puntuación 1
Sounds like you are having issues with your wifi antenna. Your in good luck it’s really cheap.
iPhone 8 Plus Wi-Fi Diversity Antenna
Imagen de iPhone 8 Plus Wi-Fi Diversity Antenna
Producto
$11.99
Puntuación 0
4 comentarios:
It's rarely the WiFi antenna. Besides, even if you remove the antenna, you'll still get one or no bars but the function will not be grayed out.
- de
If the antenna is “broken,” you get very low signal. When the WiFi function altogether is missing, then the wifi circuit is down. A lot of times from drop damage (common with iPhone 7), sometimes from electrical damage (common with iPhone 6s).
- de
What you are saying is, the TV is not turning on, it is probably the antenna that needs replacing.
- de
Thanks for all the help @tomchai @rany @refectio
- de
Can confirm it is board related. Have ran into this issue and it was still occurring after replacing all antennas.
Puntuación 0
Añadir tu respuesta
Philip Doherty estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 8
Ultimos 30 días: 19
Todo El Tiempo: 10,545
