Saltar al contenido principal
La Razer Blade RZ09-0102 es un portátil para juegos de 14 pulgadas que fue fabricado por Razer en 2013. También se conoce como la Razer Blade 2013.
Preguntas 5 Ver todo
Need a new screen
I need a new screen for a Razer - Blade 15.6" Gaming Laptop - Intel Core i7 - 16GB Memory - NVIDIA GeForce GTX 1060 - 512GB Solid State Drive - Black CNC Aluminum
Es esta una buena pregunta?
Puntuación 0
4 comentarios
Thank you so much! I found one on eBay.
- de
Hi have you disassembled the screen assembly yet? How do you do that?
- de
I am curious too if you were able to disassemble it. I was able to get the bezel off the screen with a heat-gun to loosen up the adhesive, But from there its unclear how to get the lcd out, no screws. maybe its glued in?
- de
follow up to my last post. The thin LCD screen is glued in and non-replaceable. Best option is to find someone selling a screen from a parted-out laptop on Ebay.
- de
Agregar un comentario
1 Respuesta
Solución Elegida
vgould  you need to find a model number for your Razer Blade 15 to ensure you get the proper panel. Even better would be the label from your panel. that way you know for sure that they fit. Most common display for the standard model is the LGD05C0 display which is actually a LP156WFG-SPF2 panel. Do an online search with the model number to select a trusted seller of your liking.
Fue útil esta respuesta?
Puntuación 2
Añadir tu respuesta
vgould estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 3
Todo El Tiempo: 1,199
