Saltar al contenido principal
Released on September 19, 2014, this 5.5" screen iPhone is the larger version of the iPhone 6.
Preguntas 1462 Ver todo
Charging iPhone with step down converter
Hello all,
I bought from eBay a step down converter. It converts the 12v from my car to 5V 2amp. The strange thing is that is does not charge my iPhone, but if I plug in an other USB device, like a powerbank, it charges without problem. Also I checked the output, and that was fine.
Why is my iPhone not charging with the step down converter?
I am using this kind of converter:
¡Contestado! View the answer I have this problem too
Puntuación 0
Comentarios:
Uas, does it charge any other way? What model iPhone do you have?
by
Hi, yes it charges with the normal wall charger. It is a 6 Plus.
by
Añadir un comentario
Kits de Reparación de Android
Estás a un kit de tu nueva pantalla o batería.
Comprar Ahora
Comprar Ahora
1 Respuesta
Solución elegida
iPhones can be very picky when it gets to accessories. One may be “lucky” and get a working knockoff charger at first try or buy 5 and not find even one working. Being aftermarket chargers and cables well known iPhone killers, especially the ones for cars, I’d recommend investing a few $ more and try to find a real MFI certified charger to get your phone certainly recognized and keep it safe too.
¿Ha sido útil esta respuesta?
Puntuación 2
Comentarios:
I understand it, but that is not the solutions for my card. I want to glue a usb female to the dash so I can put my lighting cable to it. I read out the pins and I get 5V at the lightning cable, but I think I do not get the amount of amps i need to charge the phone. I found this diagram on the internet: http://pinout.net/pinout-scheme/503/iPho...
Can this be a solution? Thanks!
by
1 Amp is sufficient to charge an iPhone 6, I would hardly investigate in that direction. Never thought about adding a loose Usb port since the plug and play ones for cigarette lighter come so cheap, thus I can't be of any help with that, sorry.
by
Add your answer
Uas will be eternally grateful.
Ver Estadísticas:
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 6
Global: 71
