Modelos de MacBook Pro con una pantalla de 15"
Preguntas 6306 Ver todo
Battery not Charging, no liquid damage
On June 30th I woke to find my battery with an [x] in the indicator. A quick restart and NVRAM (?) reset found brought back the battery indicator, but now it won't charge. There has been no water/liquid damage that I know of, since that seems to be the cause of this error in the other threads. I am at a loss as to what to do.
MacBook Pro 15" 2.8GHz Core 2 Duo
Model #: A1286
Mac Age: 21 months
Coconut Battery Status: -1 mAh
It works fine using the charger and running off the outlet power. But it refuses to charge. I think that I may need to replace the MagSafe DC-In board, but I wanted to ask just to be sure.
The X when I had it was Black. It is gone now, and I have a (Not Charging) indicator.
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 0
Comentarios:
Is the X red or black?
por
The X was black when I had it. Now it's gone and there is a (Not Charging) in it's place.
por
Agregar un comentario
1 Respuesta
Solución Elegida
Resolution
Shut down, then remove and reinstall the battery. Test for the issue(s) again.
Connect the MagSafe power adapter (if you haven't already) and see if the behavior continues.
If the issue(s) persist, download and install the Mac OS X v10.4.9 Update.
If the issue(s) persist, download and install Battery Update 1.3.
http://support.apple.com/kb/HT1359
Let us know your results and we can proceed.
Fue útil esta respuesta?
Calificación 2
Añadir tu respuesta
David Aaron estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 1,290
