Saltar al contenido principal
An Android smartphone produced by Samsung Electronics introduced on December 2nd, 2015.
Preguntas 53 Ver todo
I have a project! I dont know if this possible
Q1: Can i change the motherboard and all components of Samsung a5 2016 with samsung a8 2016 ??
Q2: my galaxy a8 2016 needs a screen i wanna put a full screen to body ratio how can i do that??
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 0
Agregar un comentario
Baterías para ordenadores portátiles
Un pequeño arreglo para un gran resultado.
Comprar Ahora
Comprar Ahora
1 Respuesta
Solución Elegida
I am going to that is probably not going to be possible given that the dimensions of the two boards are probably not the same and the traces are near impossible to see unless somehow you have magnifying glasses that and very careful hands. The body would not be able to accept it as the screws are most likely in different positions as well as the buttons being slightly off, and even other problems too.
As for the screen that would need as different phone shell as well meaning you want to make something custom out of old parts which unless you know how to make a 100% compatible case that does not cause the device to overheat, allows for cellular signal to get through, and can accommodate the type of screen you want with it fitting an accurate and precise measurement that only machines can do. You are best out of luck.
Fue útil esta respuesta?
Calificación 2
Añadir tu respuesta
Mohammed estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 1
Todo El Tiempo: 21
