Saltar al contenido principal
Guías y soporte para dispositivos que reproducen videos desde discos Blu-Ray.
Preguntas 108 Ver todo
My Sanyo blueRay player
My SANYO BlueRay player has stopped playing any of my BlueRay disc’s. However, IT WILL PLAY regular DVD’s. Since it plays regular disc’s , I’ll rule out a motor problem. All of my disc’s are totally free of scratches and dust free. I contacted Sanyo but they were of no help. When I insert a Blueray disc, and I click on the symbol for disc, it flashes once but then does absolutely nothing. I don’t know the 1st thing about DVD players but I’m thinking that the lens for BlueRay is dirty. What is the best way to clean it ? Any other suggestions would also be appreciated.
Thank you
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
2 Respuestas
My first suggestion would be to blow into the slot. Bigger dust parts will be blown from lenses.
Be careful to use dry air and not spit into the slot.
Many years ago this worked often with CD/DVD Drives.
Fue útil esta respuesta?
Puntuación 0
1 comentario:
I tried your suggestion, but it did not work. thanks anyway
- de
@ramses2 use one of the commercially available lens cleaner discs and run it through the process a few times. If that does not work you will have to take your Blu-Ray player apart to try to clean the lens manually. I usually wipe off the lenses with 95% (or greater) isopropyl alcohol or a cotton swab if the drive can expose the lense. This will of course only work if it is caused by a dirty lens, not a failed reader etc.
Let us know the exact model of your BR player
Puntuación 0
3 comentarios:
Hello "Old Turkey03,
I opened the main case and I see a circuit board and a case that the disc goes into. That case is connected to the circuit board by 3 wire harnesses. Now, examining the "disc case" , which I have been able to lift out, I do not see anything that remotely looks like a lens. Am I supposed to find 2 glass lenses ?
Sanyo Model # 11LE E234498
PS: on the rear of the main exterior case it says "Class 1 laser product.
Thank you for any help you have. :)
Ramses2
- de
@ramses2 I cannot find anything with that number. There does not seem to be a model from Sanyo with those numbers. check some more for a model number possibly starting with FWDV etc.
- de
Sorry Guy, I mistakenly gave you the wrong number. I had to get a magnifiying glass to find it. # FWBP706F (can't tell if that is a zero or an O)
- de
Añadir tu respuesta
Richard Whiting estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 21
Todo El Tiempo: 1,803
