Saltar al contenido principal
Anunciado el 16 de octubre de 2014, identificable por el número de modelo A1347 y EMC 2840.
Preguntas 197 Ver todo
Fusion Drive has died. What was the best recommended replacement?
My Mac Mini was taking forever to boot up and would not respond once booted. I found out in recovery mode that it has severe SMART issues on the Fusion drive.
I need some advice on what should be the best replacement option. I am thinking if it is the HDD, replace it with a SSD of similar size or larger and go from there, or just replace the SSD, if it is bad.
From what I’ve read so far, replacing the HDD is not a huge improvement, but I’d like to increase the size from 1TB to possibly 1.5 or 2 TB.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
3 comentarios:
What sizes are your current drives?
Please insert your serial number on this link and tell us your exact machine:
https://everymac.com/ultimate-mac-lookup...
- de
1tb hdd and 128 gb ssd.
- de
Which drive are you seeing the SMART errors the HDD or the SSD?
What is your systems specs model or year?
- de
Agregar un comentario
1 Respuesta
Your SSD is much smaller than your HDD. I’m going to guess your HDD is failing.
Replacing it with a new drive. I would recommend going with a hybrid drive (SSHD) like a 2.5” Seagate FireCuda. Or, if you want go with a 2.5” SSD but its going to be more expensive than a HDD or a SSDH drive Reemplazo del disco duro Mac Mini a finales de 2014
You’ll first need to break the Fusion Drive set following this guide first How to split up a Fusion Drive.
I would remove the blade SSD as its so small its quite useless. If you want some real performance you’ll want to upgrade it to a larger drive and make it your boot drive. Here’s a good reference on these drives The Ultimate Guide to Apple’s Proprietary SSDs and here’s the guide Reemplazo de SSD en Mac mini Late 2014
Using a 128 GB or 256 GB blade drive will offer a huge perforce gain and then you can have the HDD for your deep storage. This is the best long config gaining the best of a dual drive (not a Fusion Drive).
Imagen de Mac mini Late 2014 SSD
Guía
Dificultad:
Moderado
15 minutes
Imagen de Mac mini Late 2014 Disco duro
Guía
Dificultad:
Moderado
30 minutes - 2 hours
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
Avery Reddick estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 300
