Why is the laptop shutting down?
**NOTE: The seller included a 45W charger and did not make right on it. I need to get a 60W unit - I know.**
I’ve had this MacBook for a little bit and it still has thermal problems. At first I tried to repaste it and this did not work - even with a quality paste. The notebook is still shutting down under load on the charger.
I don’t believe it’s the power adapter at fault since it appears to run fine (although the notebook says 16.5V/3.65A max) despite being 14.5V/3.1A at most). I may try a knockoff adapter to see if it still overheating as a diagnostic step, but I have ordered a heatsink as a speculative diagnosis.
Since it’s so old, my budget for repairing the laptop is 30-40% of the average the value of the 2006 2121 machines, so $30-40 USD ($100 for reference). The reason for this is I can find a 2008-2009 model for about as much as a major part, should the problem be expensive to fix.
@mayer here is the CoconutBattery info you want:
@danj here’s the information with the 60W unit:
Es esta una buena pregunta?
4 comentarios
What does CoconutBattery telling us?
Is the battery even holding a sizable charge?
- de Dan
@danj It holds a perfect charge but can't charge because of the adapter. I checked when I got it because a lot of sellers lie or test it for 30 seconds and say it works.
I ordered the heatsink since it hit 165F even with new thermal paste. That's also why I don't think it's the power supply but it may not be helping.
- de Nick
Please post your results after running Coconut Battery. That 45 watt adapter, if it is Apple will charge it up just fine it it is working. Do not use a knockoff adapter.
- de mayer
Yeah... I was given a knockoff. Needless to say I ordered a genuine one on eBay (used; I don't trust anything new or open box) since it wasn't fixed soon enough. Yes, it will count against the parts cost limit unless it's a common part I can reuse so I may give the adapter a pass since I can use it with another 13" Mac or even an Air. It won't work for the 85W 15/17" ones, but I've found most of them are not in good shape. Ended up paying $12 for the OEM 60W on eBay. Would have gotten a OEM 85W but $12 (with free 2 day shipping as an upgrade) wasn't bad.
To put it in context I mentioned the knockoff in I meant for testing - I wouldn't use one of those adapters long term. I don't leave this one plugged in unless I'm using it because I know these adapters well enough to know better. The problem is the new price kills these machines, so it's used or garbage knockoff unless you own a Mac WORTH having a new one to justify the cost.
- de Nick
