Saltar al contenido principal
Lanzado el 25 de septiembre de 2015. Modelo A1688 / A1633 . La reparación de este dispositivo es similar a las generaciones anteriores, que requieren destornilladores y herramientas de palanca. Disponible como GSM o CDMA / 16 , 64 , o 128 GB / plata, oro, gris espacio, o la opcion de oro rosa.
Preguntas 2686 Ver todo
Any tips on getting the hex nut out of the phone?
How do I get this hex nut out. My bit just keeps spinning over it
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
3 comentarios
Try a smaller bit.
- de
Already did. Didn’t work
- de
Not sure if iFixit sells it, I'm sure they do, but there's actually a bit that is shapped like a hexigon, I have a screwdriver that's H2.5 (Hexigon 2.5mm) and it's a perfect fit.
- de
Agregar un comentario
3 Respuestas
Respuesta Más Útil
Use one that’s about the same size, but is slightly smaller and still fits over normally. This usually works to deal with stubborn ones.
If you’re finding it’s still being stubborn, you will need a driver with more torque. The issue is it was tightened more then it should when the phone was assembled at the factory. This isn't the end of the world but you will need to match the force used to have a chance at removal.
Fue útil esta respuesta?
Puntuación 1
3 comentarios:
I did and it didn’t work
- de
If you have that H2.5mm then you can try to put like a thin rubberband over the screw itself, and see if that adds into the empty space making your bit spin around it to add some grip to the twist.
- de
Thr rubber band thing has never worked for me @neos_hle. What usually does is a slightly larger (or smaller) screwdriver to help fit the hole better.
That said plyers are likely to damage the board beyond repair, so it's the only viable option for getting this out as a last resort.
- de
What that screw is is a stand off screw. Since its not a common screw driver at all, use a very small flathead screw driver. If it helps please give this answer a like, it would be much appreciated!!!!
Puntuación 0
Puntuación 0
Añadir tu respuesta
Owen Baker estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 5
Todo El Tiempo: 507
