Fuel Float Repair Info
While cleaning the fuel tank float on 1983 300D the aluminum wire (“V” shaped) which guides the float and helps send level info to gauge broke. I replaced it with same size copper wire. Would that effect the fuel gauge reading? What difference it makes if it is aluminum or copper while the other (“I “ shaped second wire in the unit) wire was copper as well.
Es esta una buena pregunta?
