Stop switch assembly location
Yamaha G22A gas golf car, where do I find the Stop switch assembly
Es esta una buena pregunta?
Make sure the stop switch is bad before replacing… check your fuses….
Fue útil esta respuesta?
Fuse is good cart motor will not shut off except with key Ibelieve switch is jammed on. Need location of switch.
Found the switch it is under floor panel. Lift up floor mat underneath by brake & gas pedals is a floor panel lift it out switch is underneath gas pedal. All accessible from top of machine.
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 3
Todo El Tiempo: 329
