Saltar al contenido principal
La actualización de marzo de 2015 del MacBook Air de 13" de Apple presenta procesadores Intel Core i5 e i7 de quinta generación, lo que resulta en un rendimiento ligeramente mayor y una mayor duración de la batería.
Preguntas 623 Ver todo
New battery. MacBook turns off when charger is unplugged
I followed the FixIt guide for replacing a battery on a MacBook Air Early 2015. My older battery was having trouble keeping the charge. I let it charge to 100%, then let it continue charging for two more hours. However, after setting the energy preferences so that he Mac would not turn off in order to deplete the battery, when I unplugged the power adaptor my mac turned off. I tried everything to fix this problem (SMC reset, PRAM reset, re-installing the new battery etc.). Why is this happening?
Here are some screenshots from CoconutBattery:
EDIT 1:
After checking the battery under “About this Mac” I get the following information:
CoconutBattery is saying that my battery is charging, by my Mac itself is saying otherwise. Why is this?
EDIT 2:
I reinstalled the old battery, but now this battery is not charging either. When I disconnect the power adaptor, the macbook continues to turn off. What is going on?
EDIT 3:
I performed a SMC Reset on the older battery ( removing the battery, holding the power button for 10 seconds, re-installing the old battery, pressing the power button) and now it seems that this battery is charging. However, I did this multiple times with the newer battery and it does not charge. Thoughts?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
2 comentarios
What color is the MagSafe LED? Amber or Green
- de
It is green, and on the top right corner the battery icon says 100% charged
- de
Agregar un comentario
2 Respuestas
Respuesta Más Útil
Lets check the MagSafe charger as you might have a bad cord (damaged) or the MagSafe connector is not making contact. Review this Apple T/N Find the right power adapter and cable for your Mac notebook and you could also have a bad/fake charger OEM MagSafe Chargers vs Cheap Imposters: Teardown for Truth & Compared- Fake vs Genuine Apple Magsafe Chargers - YouTube
Fue útil esta respuesta?
Puntuación 1
Pretty much a bad battery, if the old battery doesn't do this it confirms it.
Puntuación 0
2 comentarios:
@benjamen50 - I'm not sure thats the case here. I would reset the SMC to see if that altered things.
- de
I reinstalled the old battery, however now this battery is also not charging. I included photos in the original post
- de
Añadir tu respuesta
Arthur estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 249
