Cut electrical wire cord for A1243
I need to know how to replace the cable or repair it.
Es esta una buena pregunta?
If it is an USB cable that was cut then you should open your keyboard and re-solder a new cable to the PCB. Please mind to properly connect polarity of the USB power supply and Data cables. It will be 4 wires + ground so if you are handy with soldering iron then you should handle with it.
Fue útil esta respuesta?
then finish your %#*@ teardown and fix it while your doing it
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 24
Todo El Tiempo: 1,735
