Early 2009 Display Assembly on Mid 2009 system
Hi,
I was wondering if the display assembly from a late 2008 to early 2009 would fit on my Mid 2009 MacBook Pro 15” 5.4.
The connectors seem to be identical.
Thanks for your help :-)
Es esta una buena pregunta?
4 comentarios
Your systems specs: 13" MacBook Pro 2.53 GHz Core 2 Duo (with SD slot)
- de Dan
Are you up to replacing the LCD panel alone? Or do you need to replace the full display assembly (case damage).
- de Dan
I was planning to replace the full assembly. I don't have the tools to remove the glass, so buying a used assembly is the cheaper choice.
- de Arne Büsing
Then you'll need the correct assembly part as there is enough differences in the part to prevent the substitution of the full assembly.
- de Dan
