Saltar al contenido principal
Repair and disassembly information for amplifiers in home audio systems.
Preguntas 99 Ver todo
Why does my yahama amp keep blowing fuse?
Hello. Guys, I have a yamaha dsp a590, fuse keeps.blowing. Fuse is 3.15a. Located by the voltage switcher. Please assist.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
2 Respuestas
Respuesta Más Útil
@julzmatt
Double check the voltage selector and see what it is set at. If it is okay then your amp may have a short circuit somewhere in the power line of the main board. You will have to disassemble it and see if you can visually identify components that look damaged or missing. Post some good images of your board as well as the location of the fuse etc. with your question. Agregar imágenes a una pregunta existente
You can download the service manual for this amp on here
Fue útil esta respuesta?
Puntuación 1
your output stage is shorted.
Puntuación 0
Añadir tu respuesta
Julian estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 16
Todo El Tiempo: 652
