Saltar al contenido principal
Lanzado el 25 de septiembre de 2015. Modelo A1688 / A1633 . La reparación de este dispositivo es similar a las generaciones anteriores, que requieren destornilladores y herramientas de palanca. Disponible como GSM o CDMA / 16 , 64 , o 128 GB / plata, oro, gris espacio, o la opcion de oro rosa.
Preguntas 2686 Ver todo
iPhone 6s pp_tristar_acc1 no voltage
So I have problem with my iPhone and that is high battery drain so I looked online and found some test points on motherboard of my iPhone and went to check them, after probing for a bit I found that my pp_tristar_acc1 is missing (its supposed to be 4.3V). Does anybody know what that means? Is that pin output or input (I think its input), is it maybe charging connector or is it the tristar ic?
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
I wouldn’t worry about pp_tristar_acc1, it doesn’t come on unless an accessory is connected.
Battery drain is usually related to a modular issue and several things can cause this issue. You will need to isolate some variables in order to get a better understanding of what is wrong. The problem could be a bad replacement battery, excessive current draw from one of the modular components (camera, button, screen) or it could be a problem on the logic board itself.
Here are some things to try:
It could be a bad replacement battery; there are lots of cheap batteries on the market.
  • Try replacing with a known-good battery or order a good one from here.
You could have excessive current draw from one of the modular components; for example, the backlight, a camera or a sensor. You may notice a hot spot on the phone or screen.
  • Fully charge the battery first.
  • Disconnect the battery and then disconnect one modular component at a time to see if you can determine which part is bad. I would start with the front camera flex, then the rear camera, then home button.
If that doesn’t make a difference, then you should try to disconnect the screen to see if it’s the screen or the logic board
  • Disconnect the battery, then disconnect the flexes for the screen assembly, buttons and cameras, leaving only the Lightning Dock connected to the logic board (follow these guides). When you are done, re-connect the battery.
  • Go back after an hour or more and test the condition of the battery. You will need to download either coconutBattery (Mac) or 3uTools (Windows) to see the battery condition.
  • It could also be the Lightning port so you could try the same test as above but with the Lightning port disconnected once the battery is charged (connect it back to test the condition of the battery).
You may have a damaged logic board. This will require a micro-soldering repair and is not DIY. Drops, bends, water damage or using poor quality charging bricks and cables, can cause this.
Fue útil esta respuesta?
Puntuación 3
Añadir tu respuesta
Electro Discover estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 2
Todo El Tiempo: 195
