Ethernet not detecting network
Hi,
Swapped my HDD for an SSD and installed a fresh copy of Win 10.
Naturally I had some driver issues, but try as I might, My LAN connection will state “Unidentified Network” and will not connect to the internet.
Wifi is working well and connects to the internet.
Tried the driver on: https://support.lenovo.com/il/en/downloa...
Adapter is detected as “Intel 82567LM Gigabit Network”
Laptop full model is: 7454-2HU
Thanks in advance
Es esta una buena pregunta?
Hi @goom
Had you tried updating the laptop BIOS?
Had you tried using another LAN cable?
Had you tried connecting to another known working LAN port?
- de Augustine
Hi @goom ,
What is the status of the LAN adapter in Device Manager?
Go to Device Manager (right click Windows Start button, left side of Taskbar, find Device Manager link) > Network Adapters > right click LAN adapter entry > Properties > General Tab > Device Status.
Have you tried using the Troubleshooting program in Win 10?
Go to Control panel (click on Windows Start button left side of Taskbar) type Control Panel in search box > select Control Panel desktop app that appears in pop up window > Troubleshooting > Network and Internet > Connect to the internet and follow the prompts
- de jayeff
Will try BIOS.
Have tried different cables and routers.
LAN device is working and up to date.
Troubleshooter can't understand why I'm not getting an IP.
- de Goom
Did you check the antenna wires to the wireless adapter? The connectors tend to be easy to take off but sometimes very hard to connect.
- de DrGlowire
Wirless adapter works flawlessly.
- de Goom
Mostrar 4 comentarios más
