Saltar al contenido principal
Artilugio cuadricóptero de juguete con ruedas.
My battery is not charging
Hi,
I bought a parrot rolling spider a few years ago. Now I found it again, but while trying to charge, I realised it didn’t charge… I looked for tutorials online but nothing worked… I also tried to plug the drone in and than add the battery also with no luck…
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
2 Respuestas
Solución Elegida
Did you notice you battery getting weaker? If so this makes sense these batteries are not so grand and look for a battery replacement.
Fue útil esta respuesta?
Puntuación 1
3 comentarios:
I just ordered a new battery... Thanks for your quick response!! You are the best!
- de
Where did you get the battery from
- de
Where did you get the battery from?
- de
How much old your battery is?
Puntuación 1
6 comentarios:
I'm not sure but I just ordered a new one thanks!
- de
He rote in the description a few years
- de
Where did u get the battery from
- de
For srinivassai31 and others concerned; you can likely still charge an old battery. They get reluctant after sitting unused, but take it out, free of all contact, and very slow charge it for a long time. It might pump up just from that, but coaxing it along by repeating this with a little more volts each time..no more than half again its own volts, (=1½) to max at ¾ more added, will almost always get an old dead battery started again. Just watch the heat, and any swelling as signs you need to back off for awhile. Remember this is a percentage, and the smaller the battery the less added volts in a charge it can take. As example: a 12v regularly charges at 17.5v, which is half again its own volts.
- de
Hi, I bought the drone in 2016 and hardly used it for last few years. Now I have found that the battery has swollen. Please guide me how can I replace the battery.
Please note I am in India.
- de
Mostrar 1 comentario más
Añadir tu respuesta
Maximilian Klein estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 17
Todo El Tiempo: 2,955
