Saltar al contenido principal
Streams Pandora internet radio from your iPhone, connect to satellite radio, and control digital music players with the USB 1-Wire feature.
Preguntas 3 Ver todo
Why did my radio stop working?
I have got in my car and my radio hasn’t turned bk on I’m not sure why
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Calificación 0
Agregar un comentario
Skip the upgrade.
Descuento de $10 en tu factura de $50 con
SKIPANDSAVE10
Save Now
Skip the upgrade.
Take $10 off $50 with
SKIPANDSAVE10
Save Now
1 Respuesta
Could be various things that cause it to not turn on, but the most likely cause will be a blown fuse. Will have to check for your specific car where the fuse is located for the stereo. There is also a fuse on the rear of the stereo itself on some models so this may be worth a look. Other than that it could simply be a faulty stereo or loose wiring at the back of it.
The easiest way to check a fuse without the proper equipment it to pull it out an visually check if you can see a break in the wire in the plastic part between the 2 metal prongs.
Fue útil esta respuesta?
Calificación 0
Añadir tu respuesta
Kerry Sealey estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 6
Todo El Tiempo: 36
