Saltar al contenido principal
Información y guías de reparación para el iPhone 6 que salió a la venta el 19 de septiembre de 2014. Números de modelo: A1549, A1586 y A1589
Preguntas 4994 Ver todo
Phone not working after screen replacement
iPhone 6 screen was pretty busted and like the inside of the phone was even exposed in some areas. I got a replacement screen, did the replacement as usual. Battery disconnected , made sure i was gentle and what not. Just another day.
As i always do, before putting putting the plates back on i tested the screen by trying to turn on the phone. It gave me a dead battery indicator, so i was content and started screwing everything back in. I made sure all the screws went into the correct places and everything. Put the screen back into place and threw the pentalobes back in and plugged it into the charger to get it charged up before the customer comes back in for it. When i plugged the charger in it at this point it didnt show anything. I didnt pay attention to it figured it needed a second cause it was all the way dead. I come back to it 10 minutes later and nothing. Nothing shows on the screen. Tried hard resetting, tried taking it all back apart and reconnecting it. Nothing. Thought maybe the battery went bad. So i got a replacement battery put in. Still nothing. Even tried another new screen in case the screen was bad but still nothing.
Im at a loss. I dont know why it would turn on briefly and them not come back .
It is not recognized by my computer, no sound, put it under light to see if maybe theres a dim image but nothing.
Anyone experience this and have a fix?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
1 comentario:
I was thinking maybe its the charging port? Nothing showing because its all the way dead and the port is not getting power to the battery?
- de
Agregar un comentario
1 Respuesta
I assume you didn’t have to disconnect and reconnect the flex’s when adding the emf shields. Are there any marks around the connectors on the board? Does it get hot at those connectors now? Reason I ask is we just had a guy try to connect the home button and LCD connectors and was a little off. He ended up doing damage to the components right along side those connectors, and now the phone is just like you described. Good luck man
Fue útil esta respuesta?
Puntuación 0
2 comentarios:
Im not feeling any change in temperature right this moment but ill leave it on the charger for a while so i have a temperature reference. But definitely not "hot" by any means.
- de
It would get hot quick if it were a short.
- de
Añadir tu respuesta
George Troche estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 41
