Saltar al contenido principal
El HP Flyer Red es un portátil creado por Hewlett Packard que se lanzó alrededor de diciembre de 2014.
Preguntas 31 Ver todo
8, I and k keys not working, replaced keyboard and same problem, help?
So a couple of weeks ago I spilled a drink onto my latop, completely soaking it in parts. The screen went black with only a few strips of colour at the bottom. I took it completely apart and dried and cleaned it out and reassembled it. Everything works perfectly now except the 8, I and K keys. Thinking it was from the water damage I ordered a new one and replaced it today but the same keys don't work. I'm worried I damaged something removing the keyboard ribbon as the clamp holding it was extremely difficult to open. If that's the case what exactly do I need to replace to fix it?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
There might be a problem with the ribbon connector on the motherboard, as you might’ve damaged that when you were pulling out the keyboard, so if you have a way to test this, I advise that you test it.
Fue útil esta respuesta?
Puntuación 0
3 comentarios:
What methods can be used to test this?
- de
The only real way to test this is by having a motherboard that worked from a different laptop of the same kind, which would require sautering to perform, and there might be a way to test it with a multimeter and checking the pins that those keys go to.
- de
The top pictures seems to show a bit of corrosion by the ribbon cable. You can try using Q-tips moistened with isopropel alcohol to gently clean the corrosion off of the small components and traces. This may help with resolving the keyboard problem.
- de
Añadir tu respuesta
Becka Saurus estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 16
Todo El Tiempo: 593
