Saltar al contenido principal
Samsung netbook with a 10.1" screen and 1.66 GHz Intel Atom N450 processor.
Preguntas 11 Ver todo
Why windows is not turn on (no response)
i have n150 plus that do not turn on i replace the ram but nothing i saw that power led and chrging is turn on but no loading
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
1 comentario:
Have you tried putting the original RAM back in your system to see if it will boot correctly?
- de
Agregar un comentario
2 Respuestas
If your power LED light is coming on, then your power supply is working.
But if nothing is showing up on your screen, here are a few fixes you can try:
  1. Check your computer’s brightness settings. Are they turned all the way up?
  2. Check for beeps or error messages. These codes may contain clues as to what’s wrong.
  3. Check your hardware. Are all the cables inside the computer secure? Is your video card in the slot securely? Is the RAM that you added in the slot securely? Try re-seating all your RAM, cards, and cables.
  4. The problem may be your software. If the screen is blank because there is a problem with Windows itself, you may need to reformat your hard drive and reinstall Windows.
If these fixes don’t work, please tell us what was happening before the problem occurred that may have caused it. Maybe some background information can help us help you better.
Fue útil esta respuesta?
Puntuación 0
1 comentario:
It's possible the RAM he is using is not compatible with his system? That could cause some problems. Great comment about checking for beeps.
- de
i have the original ram installed in the pc
so what can i do in this?
Puntuación 0
Añadir tu respuesta
osher1446 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 58
