Saltar al contenido principal
El SanDisk Cruzer Glide es una unidad flash USB con un conector USB retráctil. Viene en una variedad de capacidades de almacenamiento con una caja de plástico negra y roja para todos los modelos.
Preguntas 11 Ver todo
usb unreadble on my tv
my usb which worked perfectly fine on my tv now gets the error of being unreadable on my tv
the only thing i did was i formatted the usb for installing mac osx
then upon reformatting using disk utility
it wont be read on the tv
while it works perfectly fine on my laptop to fop and my tv can read other usbs
i would like to know what would be the issue and how to fix it
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
When you formated the flash drive you messed it up for the TV. You’ll need to review your TV’s manual to see what formats are supported. Most only support FAT32 or exFAT.
Mac’s also supports these formats for data drives, but for boot drives and when you want Mac’s file security you’ll need MacOS’s GUID format and either HFS+ or APFS file systems.
After saving anything important on your drive you’ll need to reformat it and this time I would select exFAT so your TV can access it.
Here’s more on the differences:
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
Dhanyy dhanish estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 4
Todo El Tiempo: 74
