Saltar al contenido principal
Modelo A1181: procesador Core 2 Duo de 1.83, 2, 2.1, 2.13, 2.16, 2.2 o 2.4 GHz
Preguntas 1203 Ver todo
Display Change MacBook 2009 with a working one from MacBook 2006
Is it possible to change my damaged display with a working one from a MacBook 2006?
Thanks
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Review this guide MacBook Core 2 Duo Display Replacement Open up each part to see which system is supported. To find out what your system is exactly plug in the systems serial number into here EveryMac - Lookup. This is the best way to see if they are the same display assembly.
Do keep in mind your system uses CCFL’s so an older display will likely have a dimmer display as the tubes loose their brightness overtime (use). This would be true with any used part.
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
grafwiloff estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 20
