Saltar al contenido principal
Intel Core i5 de doble núcleo a 1,8 GHz (Turbo Boost de hasta 2,8 GHz) con 3 MB de caché L3 compartida
Preguntas 371 Ver todo
New battery says "Service" after just 4-5 months
Hey.
I have some problems with a mid 1466 macbook air and battery.
I replaced it with a brand new one, but allready after a few months it starts saying “battery needs service”.
Does it need a recalibration or SMC reset?
Anyone else have experienced this?
Best
Update (03/21/2019)
Hi Dan. Thanks for the answer, i got a hold on the macbook now. Here is picture with adaptor plugged in. Right now, if I remove power the macbook LCD goes black.
picture of coconut
Update (03/21/2019)
I have replaced battery and reset SMC. Shift ctrl alt power for 10 sec. Charger goes from orange to green to orange, as it should to confirm the reset.
Right now the Mac battery % and Coconut does not seem to agree the current charge in %
coconut after battery replacement
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
2 comentarios:
Install this gem of an app CoconutBattery take a snapshot of apps window with the MagSafe plugged in and a second with it disconnected, post both here for us to see Agregar imágenes a una pregunta existente
- de
I wouldn't worry about the discrepancy. The OS value is just updated faster than what CoconutBattery is able to.
Other than that is the system stable?
- de
Agregar un comentario
1 Respuesta
Try recalibrating the battery. It probably is thinking it’s the old battery, even though you replaced it, so a recalibration should help. If not, try removing the battery, powering on the MacBook, shut down (safely!), and reinstall battery.
Good luck!
Fue útil esta respuesta?
Puntuación 0
2 comentarios:
Thanks for answer. :)
Callibration = charge to 100% and leave plugged in for 2-3 hours more. drain battery and leave for 5 hours min. then charge full again?
Best
- de
Añadir tu respuesta
Anders Laursen estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 216
