iMac display colors messed up following hard drive upgrade to SSD
Hey there,
A friend gave me his old iMac (mid 2007), which I love working with except for the terribly slow speed. I bought a new SSD, cloned the original hard drive, followed the tutorials on how to open the machine and replace the drive, but when I turned it back on the screen colors were all messed up in a rainbowy kind of way (otherwise, the SSD seems to function well and fast!). See picture below
I did a PRAM reset - didn’t work. Thought perhaps I had done something wrong and ruined the display , so I disconnected the SSD and put back the old hard drive - the colors were still bad, but after resetting the PRAM - all was good and back to normal. I was relieved, but the speed...
Next, I tried connecting the SSD externally through one of the USB ports (using a proper adapter, which I use to connect another startup SSD to my Macbook pro and it works just fine). After booting from the original drive, the iMac recognizes the SSD, but when I restart and click the Option key to select a different drive to boot from, the SSD is not recognized. Booting with the old drive and then selecting the SSD as the startup disc from System Preferences doesn’t work either.
I thought, maybe I should remove the old drive and leave only the SSD connected externally - the iMac won’t boot.
Bottom line: I know that the display is not damaged, and that the cloned SSD seems to work just fine, except that it messes up the display parameters. I assume this is not a hardware issue with the SSD (otherwise, why would it be working just fine in all other respects??)
Thank you in advance for making the effort to help.
Es esta una buena pregunta?
