Toshiba Chromebook 2 will not run on battery power.
Toshiba Chromebook 2 will not run on battery power even though the battery indicates fully charged.
Es esta una buena pregunta?
First how old is the computer? Do you keep it plugged in all the time? The battery could be ran down or have a bad cell. I would start off by replacing the battery with a new one, or barrow one from someone that will work on just the battery swap out the batteries and see if it will then. Most likely the battery will need to be replaced.
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 27
