2.5 SSD or 3.5 SSD?
I want to upgrade my internal hard drive of my 17" Intel iMac 2006, but I don't know if I should go with a 2.5 or 3.5?
Will a 2.5 SSD fit?
Es esta una buena pregunta?
Will a 2.5 SSD fit?
3.5" SATA drive - Like these: http://www.ifixit.com/Mac-Parts/iMac-17%...
Fue útil esta respuesta?
With a little "McGyver" you can fit a 2,5" SATA disk or SSD. The 3,5" to 2,5" reduction frames hold the HD smack in the middle of the frame. Normally the cabels are too short, then. But you could build your own frame or even use double sided tape. I'm doing this job to my own iMac tonight, because the 3,5" drive fittet now is too noisy.
That's what this is made for: http://eshop.macsales.com/owcpages/multi...
I used a Newer Tech AdaptaDrive 3.5"–2.5" adapter to mount a 2.5" SSD in my early 2008 iMac. It worked flawlessly.
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 3,254
