Saltar al contenido principal
Reloj inteligente deportivo con Bluetooth lanzado en marzo de 2016. Modelo: FB502SBUL
Preguntas 53 Ver todo
Fitbit Blaze only works in charger
My Fitbit Blaze works fine in the charger but shuts off immediately if the charger is unplugged or the watch is taken out of the charger. Can’t even reset using the reset procedure from Fitbit as there is no power at all. Shows 100% when in the charger. Is the battery a realistic possibility? It can’t imagine it is but the alternative sucks.
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
Hi,
If it works on the charger but not when on the battery only, then most likely the battery has failed and needs to be replaced.
Here’s a link to the ifixit Fitbit Blaze Battery Replacement guide, which shows how to replace the battery.
ifixit sell a battery for the watch. Here’s a link Fitbit Blaze Battery
There are also other suppliers that may suit you better. Just search online for LSSP321830 to get results.
Imagen de Fitbit Blaze Battery
Producto
$19.99
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
Chris Chandler estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 6
Ultimos 7 días: 22
Ultimos 30 días: 75
Todo El Tiempo: 5,067
