Saltar al contenido principal
Guías de reparación y desmontaje para microondas Kenmore
Preguntas 182 Ver todo
model 721.86013010, f5 error code, humidity sensor,
replaced humidity sensor but error code remains, bad replacement sensor?
Es esta una buena pregunta?
Puntuación 0
2 comentarios
Thermistor changed, cleared F-5 error, relay clicks but no microwave power, noticed a fuse inside, could that be the problem now? Don't have time to take the cover back off to check the fuse right now.
- de
If i have the F-5 error code should I change out both the humidity sensor and the thermistor to be safe? anything else causing the F-5 error?
- de
Agregar un comentario
2 Respuestas
Solución Elegida
You did fine on replacing the humidity sensor.
The other cause for this code is the
Thermistor
Here’s the part:
LG OEM Part #6322W2A001A
https://www.repairclinic.com/PartDetail/...
Fue útil esta respuesta?
Puntuación 2
1 comentario:
F5 code stands for Damper switch sensing error on Model no. 721.86013010 also for models 86012/86019 .
- de
code errors for kenmore elite microwave model no. 721.86013010 and 86012/86019
Puntuación 0
Añadir tu respuesta
sam estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 7
Ultimos 30 días: 35
Todo El Tiempo: 2,880
