Saltar al contenido principal
Modelo A1059 o A1099 / disco duro de 20, 40 o 60 GB / rueda de clic sensible al tacto
Preguntas 227 Ver todo
Pregunta Cerrada
My iPod died suddenly after 6 years of 'signal service', dead battery?
The iPod, a 4th Gen. 60 GB HD model has been working faultlessly all this time, but gave up while being recharged after hitting the red line while in use. My opinion was that the battery had done its dash. There is no light, no life, with almost 5 GB of space still to add more 'books'.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
2 Respuestas
Respuesta Más Útil
Does the ipod work when plugged in still? If it works while plugged in, or says something about waiting for the battery to charge, then the iPod is probably still good. If it gives a sad ipod or a folder symbol, then it *might* be the battery, but probably not. I would try buying a battery, its worth a shot either way and they are fairly cheap.
Are you still using the original battery after 6 years? Wow, impressive.
Fue útil esta respuesta?
Puntuación 2
Cody, your take might've been helpful if only the iPod showed some life. Everything is plain dead, no show, nada! I've opened the Pod, removed and checked the battery which shows a full 4.10 Volts across the +, - terminals. I don't know what the white lead out controls.
I ran a 6 volt 0.5 A torch globe for several minutes across the red/black leads, the battery still reads 'high' i.e; 4.10V.
Does this suggest a logic issue, a mechanical, or switch malfunction? The thing worked o.k. right up to when I decided to recharge the battery which was then showing almost zero life after my near 3 hour bike ride with constant use. It was never dropped.
Yep! I am stumped, and though I'd rush to buy a new pod, I hate giving up without a fight, besides, I love this "old faithful", so, I'll just keep digging, in the hope that someone has a spot on clue.
Puntuación 0
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 7
Todo El Tiempo: 1,698
