Saltar al contenido principal
Modelo A1200 con procesador Core 2 Duo de 2.16 o 2.33 GHz
Preguntas 113 Ver todo
hard drive replacement manual
I have searched the manuals and cannot find one on the hard disk replacement of the EMC 2111 24" intel imac.
I understand that there is one but cannot find it.
Es esta una buena pregunta?
Puntuación 2
Agregar un comentario
2 Respuestas
Solución Elegida
Doesn't appear to be one on the site. But for what it's worth, here's a Macworld article by Kyle Wiens describing the process, though (along with links to other ifixit guides for similar models): http://www.macworld.com/article/145116/2...
The key quote: "The later G5 iMacs and first Intel models are tough: They have nasty retaining clips holding the front bezel in place. Removing the bezel requires a flat pry tool, such as a credit card or ID badge. You also need to completely remove the LCD display and lower EMI shield before you can access the drive. Rating: Difficult"
Fue útil esta respuesta?
Puntuación 2
Someone woke this one up after 3years, I thought I might as well update the answer. The guide for the hard drive replacement can be found right here
Puntuación 1
Añadir tu respuesta
David Randall estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 2,369
