Saltar al contenido principal
2.26 o 2.4 GHz / Carcasa Unibody de plástico blanco
Preguntas 645 Ver todo
How do I know if I need an entire display assembly or just a new LCD?
My macbook display often freezes with a series of colored lines, or goes completely grey. Jiggling the display or moving the assembly brings it back. How can I tell whether I need to replace the entire display assembly, or just replace the LCD panel? The camera works fine. And the display colors and brightness are great. The only problem is that it goes blank often.
Update (01/25/2019)
Just wondering if I can avoid the expense of an entire display if the LCD panel will correct the problems. Both repairs seem pretty straightforward.
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
2 Respuestas
Solución Elegida
I’d suggest diagnosing the problem before you attempt repairing it.
Hook it up to an external monitor and see if it goes black when your LCD does. This will tell us if it is a GPU issue.
Next when the screen goes black, hold at flashlight at an angle and let us know if you still see the desktop dimly.
This sounds like a cable issue to me (because it clears up when you move the display).
Reseat the LDVS cable as seen in step #9 of this guide:
Remplazo del Cable de Datos de la Pantalla/Camara en el MacBook Unibody Modelo A1342
Fue útil esta respuesta?
Puntuación 2
2 comentarios:
Thanks. An external monitor does stay fine even when the laptop display goes bad. I will reseat the cable as you suggest.
- de
Re-seating the LDVS cable did not work. But I removed the LCD display and re-seated that cable. Tricky procedure, trying to reconnect that cable. But it seems to have greatly improved it.
- de
I like swapping out the whole top half just because its less hassle. but if you have the time and patience and lcd swap isn’t impossible just a little more tedious :)
Puntuación 0
Añadir tu respuesta
Steve A estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 78
