Saltar al contenido principal
Lanzado el 25 de septiembre de 2015. Modelo A1688 / A1633 . La reparación de este dispositivo es similar a las generaciones anteriores, que requieren destornilladores y herramientas de palanca. Disponible como GSM o CDMA / 16 , 64 , o 128 GB / plata, oro, gris espacio, o la opcion de oro rosa.
Preguntas 2683 Ver todo
Customer says phone sometimes won’t charge?
So I got this phone and they told me it sometimes won’t charge, so to change the charge port. When I first got the phone sometimes it wouldn’t charge, I took the battery out and it’s not doing that anymore but I’m hesistant to send it back until I have tested the charge port. How do i test for a faulty charge port if the phone is completely charging? If I send it back I’m hoping it won’t return to not charging when they get the phone back.
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
The battery is the weakest link so by changing the battery and the phone now charges correctly, you probably have solved the problem completely. You could try to overlay a replacement charge port (no need to do a full install) to see if that makes any difference.
Intermittent problems are always the worst kind of problem and the only way to know for certain is to give it time. Either let the customer try it out, under the expectation that it may come back, or have the customer leave the device with you for a few days so you can test it under several charge cycles.
Fue útil esta respuesta?
Puntuación 2
Añadir tu respuesta
Jesus flores estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 56
