Saltar al contenido principal
El PowerMac G5 es un ordenador de escritorio producida por primera vez en 2003 por Apple Corporation. Esta guía revisará el proceso de reparación de un número de modelo Apple PowerMac G5 A1047 EMC 2061 de 2004.
Preguntas 193 Ver todo
Which Power Supplies Are Compatible?
Earlier today, I picked up a broken PowerMac G5 from a flea market. It's a dual 1.8Ghz model from June 2004. (A1047) The unit wouldn't turn on, so I figured that it had a dead power supply. I confirmed this later, by modifying an ATX (PC) power supply to run the computer. It boots up with the modified ATX PSU, so I'm planning on buying a replacement for the original. The original power supply is a 600W AcBel. I've seen a few different wattage power supplies on eBay, and want to know if I can use a 450W unit (Somewhat cheaper than a 600W) instead. Would this be possible, or would I need to buy a 600W PSU?
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
2 Respuestas
Solución Elegida
You'll probably be alright unless you start loading it up with PCI cards and a lot of extra RAM. Hopefully you got the original system installations disks that have the fan syncing software (this is needed when changing any major component.
Fue útil esta respuesta?
Puntuación 3
1 comentario:
I might have a set of disks laying around. if not, then I'll just buy a set. I'm probably just going to sell it, so I'll get it up and running.
- de
If your system has a 600W PSU then I suggest that's' what you need to replace it with.
Puntuación 2
Añadir tu respuesta
Chris Green estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 4
Todo El Tiempo: 2,086
