Saltar al contenido principal
The March 2015 update of Apple's 13" MacBook Air features fifth generation Intel Core i5 and i7 processors, resulting in slightly increased performance and battery life.
Preguntas 271 Ver todo
Why does my MacBook make weird sounds?
My MacBook makes weird sounds since yesterday evening. It rattles in regular intervals, kind of like breathing. Any suggestions what that could be?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Calificación 0
Agregar un comentario
Kits de Reparación de Batería de iPhone
Sólo $29.99
Buy Now
Sólo $29.99
Buy Now
1 Respuesta
Respuesta Más Útil
The most common mechanical sound is the cooling fan. Often times dust and debris builds up on the blades causing them to become unbalanced so the blade hits the wall making sound.
Simply put your system needs a good internal cleaning. Get a small soft paint brush and a can of can’ed air. Pop off the bottom cover following this guide MacBook Air 13" Early 2015 Lower Case Replacement so you can carefully scrub the logic board and the fan of the build up junk and then use the can’ed air to blow it away.
Fue útil esta respuesta?
Calificación 1
Añadir tu respuesta
nonafina estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 1
Todo El Tiempo: 30
