LCD screen broken with water - what to do?
Hey
Water in my LSD. what to do here?
Es esta una buena pregunta?
Hey
Turn off the computer and disconnect the battery. Set it somewhere to dry for 48 hours, or until the water is completely gone. Do not power on the computer until the water is completely gone or you risk damaging other components. If the problem persists for more than 3 days, I would replace the LCD.
Fue útil esta respuesta?
You can't replace the LCD alone you need to replace the full assembly MacBook Pro 15" Retina (Late 2016-2017) Display Assembly. I hope you're sitting down as its quite costly.
Hopefully you don't have any water in the main case that would be bad!
Turn it off, disconnect all leads etc and place it in a container of uncooked RICE & leave for at least 24hrs.
The rice will act as an asborbent & will soak up most of the water which remains
Sorry guy, This is an urban legion! Rice is no better than stale bread or a dry sponge ;-} Rice or silica gel will only pull moisture out of the air it won't pull it out of a device.
You need to pull the unit apart to mop up the wetness or just replace the part.
Here some heat or a vacuum might drive the moisture out thats about the best you could do as the display can't be opened effectively.
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 320
