Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Cepillo de dientes recargable Oral-B Vitality de Proctor & Gamble con un temporizador de 2 minutos. Número de modelo D12513. Tipo de mango: 3709
The timer does not work on the toothbrush. How can I fix it?
We bought our boys this the OralB Vitality toothbrushes for Christmas. The timer does not work, we have to turn them off manually. Can the timer be set or reset?
Es esta una buena pregunta?
Puntuación 1
1 comentario
Changed the battery a few times and and still didn’t come back on. How do I know it’s the timer or it’s defective?
- de
Agregar un comentario
1 Respuesta
Solución Elegida
Hi @laurelle ,
This is from the Oral-B website
The two-minute timer on our Oral-B Vitality toothbrushes should reset if the toothbrush has been switched off for 30 seconds. If you switch it off before the 2 minutes are up, and then switch it back on within 30 seconds, it will resume from where you left off.
If it does not perform this way it may be faulty.
There is a 2 year warranty on the product (may be country dependent - check in your location).
Contact Braun service, regarding replacements.
Fue útil esta respuesta?
Puntuación 3
Añadir tu respuesta
Laurelle estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 29
Todo El Tiempo: 16,832
