Antenna went bad slowly 3 times
My antenna has slowly gone out on my iPhone 6. It started by going to roam in places where I used to get service, then it just went to searching. Resetting network settings worked a couple times, but only for an hour or so. Replaced SIM, nothing. Had the internal antenna replaced and it worked for a day or two and then went to roam and then searching. I replaced the internal antenna and WiFi antenna and the same thing again, roam and then searching. What could be the cause of my issues? Rear case “actual” antenna issues?
Es esta una buena pregunta?
2 comentarios
Would a typical repair shop be able to perform this if it needs it. Slide my SIM card back in and it worked for a second, then checked the “flatness” of the phone and gave it a good press seems to be work long for the time being.
- de Walter
@wmyoungiv If the repair shop does microsoldering it should be able to fix it in most cases by removing the chip and reworking it, disposing of the oxide and/or most fragile solder joints. If the board inside lays flat contacts might work longer but it's usually a matter of time that signals/power will stop flowing completely if not taken care of.
- de arbaman
