Saltar al contenido principal
La TI-84 Plus CE es una calculadora gráfica lanzada en la primavera de 2015 por Texas Instruments. Incluye una pantalla a color de 2,8 pulgadas, puerto USB, aplicaciones, almacenamiento y una batería de 1200 mAh.
Preguntas 82 Ver todo
Calculator Isn't Charging, Cable seems to work however.
For the record, I’m not using the original power supply that came with the calculator to charge, however it should do fine. (1A 5V) When I plug the cord into the calculator, the red light appears, then the calculator turns on. The red light starts flashing. The calculator does not seem to acknowledge the charging. The strange thing was that when I removed the battery, the light just stayed green, but the calculator wouldn’t turn on, so the cable is working, right? When I hit the reset switch, the red light becomes solid, but as soon as I let go, back to blinking. Any advice would be helpful, thanks.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Respuesta Más Útil
Just to clear one thing up, the calculator can not run just off of the cable. It is expected behavior that when you remove the battery and just plug the cable in that the light turns green. :)
I Looked into the flashing red light and I think means you have an improper power source. My best guess is your power brick is faulty. Can you try a different power brick or connecting the calculator to your computer and see if it will properly charge?
You might be able to get more information about this by running a self-test.
Press [mode]
Press [alpha]
Press [S]
Press [enter] three times
Press [3]
If you need help with this there is a video about it here. This will tell you if the calculator is charging but it might also tell you if something is wrong with the connection.
Fue útil esta respuesta?
Puntuación 2
4 comentarios:
Thanks for replying, you cleared some things up for me. I ran the test, and then plugged it in to the same supply, then reran the rest, and now the charging is working. I'll write if it fails at any point, and if not, will accept this answer. Thank you.
- de
Great, I'm glad it's working! Let's hope it stays that way.
- de
@plproductions Still working for you?
- de
this saved my calculator, thank you so much!
- de
Añadir tu respuesta
PLProductions estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 28
Ultimos 30 días: 104
Todo El Tiempo: 19,544
