help! my seiki se48uxc4tca 4k tv is flikering
Hi i’m new here.
i own a 48 inches 4k Seiki Led TV and it started to flicker after 10 minutes on.
the menus in Netflix or the TV itself are displaying fine but streaming via wifi or direct tv with hdmi is flickering.
I made i little video to help you understand what’s the main problem on the screen.
Now i’d like to know if it looks like some board i could buy and replace or if it looks like a panel issue.
Es esta una buena pregunta?
2 comentarios
Que precio tienen él display de pantalla 32 pulgadas seiki
Y puedoreparalo se dañaron las venas o flexiones roto gracias
- de pedro alvarez vega
@pedro alvarez vega Hay una etiqueta en la parte posterior del panel LCD. Eso identifica el modelo exacto y el fabricante. Use esos números para hacer una búsqueda en línea de un reemplazo.
Google Translation
There is a label on the back of the LCD panel. That identifies the exact model and maker. Use those numbers to do an online search for a replacement.
- de oldturkey03
