iMac Intel 27" Retina 5k Display Backlight don't work
Hey,
can anyone help what should be done when the screen does not work?
Apparently, the display panel is broken, the backlight is not visible, but the picture comes on when it reflects with a flashlight.
Is it possible to fix this or should I change my display panel?
Info: This iMac screen stopped working suddenly, no flickering, etc ..
Thank you!
Update (12/30/2018)
Thanks for the answer. How much could this cost?
Yes, my iMac has been opened once. Here too, this "part" has broken, but should it not have an effect? i’m right?
Es esta una buena pregunta?
1 comentario
The connector is the display power connector. So it the cable was forced in backwards you could have done some serious damage to the logic board.
So, the issue is how much damage is present some won't be visible as in the case of the connector. This is going to take some work to fix. Best to find someone with the deeper tools, skills and access to the needed parts.
- de Dan
