Saltar al contenido principal
Modelo A1181: procesador Core 2 Duo de 1.83, 2, 2.1, 2.13, 2.16, 2.2 o 2.4 GHz
Preguntas 1196 Ver todo
Dirty Ports?
There is a lot of buildup of dirt on the case where it recesses into the port openings. Is it a problem and what is the best way of cleaning it?
Es esta una buena pregunta?
Puntuación 2
1 comentario
I used a blending/ fluffy make up brush and that did the trick. Soft, clean and easy to get. I found it easier to use then the q-tips
- de
Agregar un comentario
6 Respuestas
Solución Elegida
use q-tips or compressed air to try and clean the ports
as for it being a problem there shouldn't be one as long as it doesn't mess with the connection
Fue útil esta respuesta?
Puntuación 3
1 comentario:
Its too stuck for compressed air but i will try the q tips
- de
If the muck is really stuck on, you can use a small amount of alchohol on the Q-tips to help unstick it.
Puntuación 2
Q-Tips or dry cotton wool should clean your ports well.
As for the mag-safe charger port, the magnetism can hold some dirt to it. This can be hard to remove but Q-tips and a little extra effort should clear it out
Puntuación 2
A soft toothbrush can be used to loosen debris, then use a little compressed air to blow it out. If you are going to use alcohol, be sure to remove the battery first, to avoid shorting anything out.
Puntuación 2
I advise against alcohol, if it get's in the port- your port may end up permanently screwed. Ditto at the compressed air though.
Puntuación 1
Used a clean make up brush and that did the trick of removing any sand, dirt, lint from the charging port
Puntuación 1
Añadir tu respuesta
AussieMac estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 18
Todo El Tiempo: 11,170
