Saltar al contenido principal
Intel Core i5 de doble núcleo a 1,8 GHz (Turbo Boost de hasta 2,8 GHz) con 3 MB de caché L3 compartida
Preguntas 371 Ver todo
How to test if logic board or battery is issue? (MB Air 13" mid '12)
My MacBook Air Mid 2012 recently stopped working unless plugged into the charger. The battery appears to have disappeared, though Apple Hardware Test doesn’t find any faults. Coconut battery doesn’t find anything and the System Information produces:
Battery Information:
Charge Information:
  • Charge Remaining (mAh): 0
  • Fully Charged: No
  • Charging: No
  • Full Charge Capacity (mAh): 0
Health Information:
  • Cycle Count: 0
  • Battery Installed: No
  • Amperage (mA): 0
  • Voltage (mV): 0
SMC and PRAM resets have done nothing. Does anyone have any experience in whether this is likely to be a battery or a logic board issue? The battery was replaced in May with a third party battery. Is there another test I can do other than buying another battery?
Thanks,
Sam
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
1 Respuesta
Solución Elegida
The micro controller within the battery is not responding!
Which is why the system is not seeing it. Sorry, you’ll need to replace the battery. Given the age of the system it’s likely well worn as well.
Fue útil esta respuesta?
Puntuación 3
1 comentario:
Cool: thanks. I wasn't sure which it was.
I realise the system is old, but it is a favourite!
- de
Añadir tu respuesta
Sam estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 2
Ultimos 30 días: 13
Todo El Tiempo: 124
