Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
El iPhone 5c de Apple fue anunciado el 10 de septiembre de 2013. La reparación de este dispositivo es similar a los modelos anteriores, y requiere destornilladores y herramientas de entrometimiento. Disponible como GSM o CDMA / 8, 16, 32 GB / Blanco, Rosa, Amarillo, Azul y Verde
Preguntas 1592 Ver todo
iPhone does not charge and there is water damage - how to fix?
My iPhone does not charge with most cables (sometimes it works but very rarely) and the battery dies very fast. I send it in because it was still under warranty, but they sent me this picture to show there is water damage (so they can’t repair it).
Is the damage irreversible? Can I fix it myself? Which guides should I follow: change the battery, the docking station, what to do about the water damage?
Thank you!!!
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
Apple’s water detectors trigger even when there was no liquid but a really high humidity. Basically, it’s their way to say “F you!” and make you buy a new phone or parts that worth just as much as a new phone. Just send it to third-party reputable repair shop and ask them to take a look on your 5C’s USB port, if replacement (that you can make) won’t help or you’re afraid to go deeper (that can also needs to be done in some cases).
And check more cables on your phone or those cables that didn’t work on other devices. If they still don’t work, then it’s just straight bad luck and you got faulty cables. Is they work as usual (it also means that they charge as fast as usual), then you might consider replacing USB port.
About those practices: https://www.youtube.com/watch?v=_XneTBhR...
Instruction on replacing Lightning port: iPhone 5c Lightning Connector Assembly Replacement
Fue útil esta respuesta?
Puntuación 0
Comentarios:
Thank you for the help!
- de
Añadir tu respuesta
Myrah estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 20
