Saltar al contenido principal
Número de modelo A1707. Lanzado en junio de 2017, este MacBook Pro presenta procesadores Kaby Lake de hasta el procesador Intel Core i7 de cuatro núcleos a 2.8 GHz con Turbo Boost de hasta 3.8 GHz.
Preguntas 324 Ver todo
Display goes black when lid opened more than 80 degree MacBookpro 2017
My macbook pro 2017 Display goes black when i open the lid more than 80 degree and my warranty lapsed last month. Can anyone help me knowing what exactly could be the issue and what part will solve?
Last thing will apple repair it for free?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Respuesta Más Útil
You are facing a known issue with the new displays in the 2016 onwards systems. Unlike the older models which has the T-CON board within the display lid and uses iDP (eDP) signaling to the logic board (using just a few lines), this series places it within the main body cavity. This design has a fair amount of connections between the display its self (LCD) and the T-CON board is quite large Apple uses a set of ribbon cables between the lid and the T-CON & the main logic board as you can see here:
The Purple cables carry the image data, and the one Blue cable offers the backlight power.
In any case there is nothing you can fix here. You’ll need to visit the Apple Store and press for a warranty exception.
Time is the essence here! You need to get to Apple ASAP as the longer you wait the less likelihood they will cover it.
FYI: If you did this out of your pocket it will cost you $600 Ouch!
Fue útil esta respuesta?
Puntuación 5
3 comentarios:
@danj if i spend 600$and repair it, Will it happen again in future? or they will repair new way?
- de
@amitg - I can't say what Apple is doing here. So far the systems which I know of haven't encountered the problem again.
- de
If it is still under warranty, buy an additional two years of AppleCare for insurance.
- de
Añadir tu respuesta
Amit estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 137
